Alright, so I'm building my first LC rig. I've been building air cooling for 8 or 9 years for me and my friends and their friends... But I wanted to try liquid cooling.
First up is the case: MAGNUM SMH10 from CaseLabs. (http://www.caselabs-store.com/magnum-smh10/)
Case Color: White Matte
Form Factor: HPTX
ATX Layout: Standard
MB Door: XXL Window (30.00)
Window Color: Gray
Top Cover: 120mm Ventilated
Lower Chamber Covers: Ventilated
PCI Backplate: Hex Mesh
Shipping Format: Flat-packed
Flex-Bay Covers: Solid
Next up is radiators:
Black Ice GTX Xtreme 480 in push-pull mounted in the top compartment
(http://www.frozencpu.com/products/5327/ex-rad-110/Black_Ice_GTX_Xtreme_480_Radiator_-_Black.html)
Magicool Extreme Quad 120 both in pull mounted sideways in the bottom section.
(http://www.frozencpu.com/products/12724/ex-rad-232/Magicool_Extreme_Quad_120mm_Radiator_LC-RADI480S.html)
And now, we come to res/pumps.
http://www.frozencpu.com/products/16942/ex-res-421/XSPC_Twin_D5_Dual_525_Bay_Clear_Reservoir_-_w_Dual_MCP655_Series_Pumps_Installed.html
X2 with MCP-655 PWM mounted in the front flex-bays
I'll also be using
Alphacool g1/4 45 degree rotary compression fittings 1/2"X5/8"
(http://www.frozencpu.com/products/16085/ex-tub-1302/Alphacool_G14_Thread_45_Rotary_12_ID_x_58_OD_Compression_Fitting_-_Copper.html)
with PrimoChill White 7/16"X5/8"
(http://www.frozencpu.com/products/17880/ex-tub-1613/PrimoChill_PrimoFlex_Advanced_LRT_Tubing_716ID_x_58_OD_-_Elegant_White_PFLEXA-758-W.html)
Using Pearl Anti-Kink coils
(http://www.frozencpu.com/products/6626/tsl-32/PrimoChill_Anti-Kink_Coils_-_58_OD_Tubing_-_Pearl.html)
I'm using 4 Universal GPU blocks
(http://www.frozencpu.com/products/17555/ex-blc-1365/HEATKILLER_GPU-X_Core_LC_Universal_VGA_Water_Block_17000.html)
and copper heatsinks for VRM and VRAM on 4 7970's
I will be using a Full Copper EK Supremacy CPU block
(http://www.frozencpu.com/products/16688/ex-blc-1180/EK_Supremacy_Universal_CPU_Liquid_Cooling_Block_-_Full_Copper_EK-Supremacy_-_Full_Copper.html?tl=g30c325s842#blank)
Fans are Koolance High Performance for case and radiators.
http://www.performance-pcs.com/catalog/index.php?main_page=product_info&cPath=36_1130_403&products_id=23747
Fan controller:
http://www.frozencpu.com/products/17109/bus-320/Akasa_FCSIX_6_Channel_Aluminum_Fan_Controller_-_20W_per_Channel_-_Black_AK-FC-08BKV2.html
I'm looking for suggestions, things to improve, or any obvious holes that I left unfilled in the loop.
Form Factor: HPTX
Window Color: Gray
I'll also be using
Fan controller:
