(when it comes out not the torrent versions) I have been doing some reading on what it will take to run the new OS
and get best results like video cards, RAM etc...etc but I want to build a system that will take what ever I throw at it
I would like to use an Intel processor and system board or a board that is better I really don't want an use AMD processor
not because of anything bad I just have had great luck with Intel as far as being a workhorse and I don't really have to worry
about a heat problam as much, I know this sounds silly but the PC I am using now is one I built about a year or so ago and it has what
I thought were the best components on the market at the time and with a lot of advice from folks on this website it turned out to be
a monster of a computer, but the next one I build I want it to be Shall we say a "BEAST" I do this as a hobbie and I know its sounds
abit crazy, and like I said I know it's a little to soon to think about this because components seem to get better and faster daily,
now that I've finished rambling on what I would like to know is what would yall do if you were going to build a computer that would
do be a "BEAST" would you go with 64bit or 32 bit 1000s of megs of RAM etc..etc, I figure if Vista is supposed to be the next
generation in Operating Systems then why not build the next generation PC, so any input will help, and again thanks for all the
help in the past, because when I build this "BEAST" I'm sure I will need you're help again, and I hope everyone is having a good
and will continue to have a great 2006.
NoSpark3
