Building a Dual Core System
678 6
In the near future i am planning on building a new system. These are the main specs.
Gigabyte K8N pro-sli Nvidia nForce 4 SLI MCPS PCI-E Chipset.
AMD 64-939 x2 Dual Core 4200+
200gb W.D Hard Drive
2x Nvidia 7800 gt (sli)
Shaw 550 watt deluxe atx
LG DVD -+rW, cd rom, fdd and all the other stuff.
What i would like to know is if this configuration would work well or not. Any suggestions on the specs will be helpfull.
1 - 7 of 7 Posts
Looks like a good rig but i would change 2 things being the mobo to a asus or dfi brand, gigabite is not the best when it come to overclocking so i have heard; and as for the psu dont know that brand name but i would change to a seasonsic 600w, antiec truecontrol 550w, ocz 520w or 600w, or if ya got the money pc power and cooling 510w.
OG
Don't get 1.5 gigs of ram.Get two 1 gig of ram and run them in dual channel(better performance).I would suggest getting an AMD 4400x2 instead of a 4200 cause it has more cache and its built on a better core.If you don't have enough money for the 4400x2 then I suggest dropping one of the 7800 GT's and then pick up another one down the road.
hope that helps.
Edit=I would still get a different motherboard if I were you preferably Asus if you don't wanna overclock too much.
OG
Sorry for the double post but try and pick up a 550 watt sunbeam nuo i've heard great things about them or if you prefer seasonic they are also very good psu's.
Thanks guys for your help. At the moment the Dual Core 4200+ is the best value but later down the trak the 4400+ should be better value so i will consider it. I would consider getting 2gb of ram but 1 gig sticks cost a lot at the moment so 512 mb sticks are better value.
1 - 7 of 7 Posts
