There's really no need for aftermarket cooling if he's not overclocking. Stock cooling suffices at stock, it's guaranteed to.
Originally Posted by Robilar My friend requested that i build him a new system. He's a real noob but had some specific requirements: Intel Processor Dual Core Asus Motherboard SLI (has to have it, saw mine I guess) 1 GB RAM Doesn't want raid Definitely no overclocking doesn't need monitor or peripherals He is going to use it for some gaming and working at home (he's in the financial industry, so numerous spreadsheets, hence the dual core). These are my thoughts so far: Intel D930 3 Ghz OCZ DDR2 PC2-5400 667 Mhz 2 x 512 MB Dual Channel 4-4-4-8 Asus P5N32-SLI Dual BFG 7800GT's Seasonic S12 600W NEC 3550 DVD-Burner 74 Gb Raptor Primary, WD 250 GB Sata-II backup SB Audigy 2 Zs (he wouldn't know the difference for the X-FI) Antec P160 Case (tried to recommend the 160W with window but he's not interested but definitely likes the other aspects of the P160W I own). As he won't be OC'ing I will leave the stock cooling on the video cards but I am recommending to him the Zalman 7700CU for cpu (as I know intel runs hot) or perhaps the big typhoon. so far what I listed is in his budget. can anyone offer any improvements? Thanks |
thanks for the input manual. Thats the kind of info I need before recommending to him. If not the A8N32, which Asus board would be ideal for SLI? He definitely won't shell out the dough for 2 x gtx. Also which dual intel chip would you recommend. I doubt he would mind spend another $200 or so but not much above that. the attached pic is the 160W with its side door detached. 2x120mm fans (front open intake, a must in my book). |
Originally Posted by pauldovi Also, me may want to think about waiting for the Conroe to come out in April... There is no word on Nvidia chipset and conroe support though... |
