My 3770k just isn't what it used to be, and some CPU intensive games are taking hits and not able to use my GTX 1080 to its fullest extent. I've seen benchmarks for the new 8700k and its pretty much blowing most CPU intensive games out of the water compared to the 3770k when paired with a 1080 @1440p.
I have about $1500 budget and I have to buy a new motherboard and RAM for the upgraded CPU, plus I'd like to get a good liquid cooling system so I can OC to 4.8-5Ghz (optimistically).
Here are my suggestions so far:
CPU: https://www.newegg.com/Product/Product.aspx?Item=9SIABT16MV1065&cm_re=8700k-_-19-117-827-_-Product
Motherboard: https://www.newegg.com/Product/Product.aspx?Item=N82E16813119032
RAM: https://www.newegg.com/Product/Product.aspx?item=N82E16820233853
Cooling: https://www.newegg.com/Product/Product.aspx?Item=N82E16835181100
Is there anything you would change on my list or are those good products to pair with a 8700k? I don't know much about liquid cooling and the 8700k can only handle up to 2666mz RAM as far as I'm aware so I think that's good for now? All that adds up to $1260 so I have some wiggle room if you guys have better suggestions.
