1 - 20 of 21 Posts
Well I decided that my gtx 570's have served me well. I'm am going to give my whole current rig to my son and build a complete new one. Here is a list of what I think I am going to use. Just ironing out the details.
CPU: I7 Sandy Bridge @ 3.4
Cooler: Corsair H100
MB: EVGA Z68 FTW
Case: Corsair Obsidian 800D
4x120MM Noctua Fans (forH100)
3x140MM Noctua Fans (for case)
Memory: 16Gb G.Skill Ripjaws X series (4x4GB 1600MHZ)
OS Drive: Corsair Force Series SSD 120GB
Programs Drive: Western Digital VelociRaptor 10000RPM 600 GB
Storage: Western Digital 2TB
PSU: XFX Pro Series 1050W Gold cert
GPU: 2x EVGA GTX 680 2GB (will add a third down the road)
Sound Card: Asus Xonar Essence STX 7.1
Blu-ray: Asus bw-12b1st/blk/g/as
DVD: Asus 24x DVD writer
Mouse: Wireless Cyborg R.A.T
Keyboard: Undecided
Monitor: Undecided
Cost should remain just over $3,000 Which is about average for my new builds. This doesn't include monitors as I don't count them as part of my builds. After all I don't upgrade monitors nearly as often as my rig.
Speaking of which I don't know what I want to do for a monitor, I'm torn between 3x22" Samsungs for surround, or one good 27 or 30" monitor. Any ideas
You broke it!
One heck of a system......
A friend of mine had the Cyborg RAT and didn't care for it, I used it and didn't care for it either. If you get it I would recommend getting a second at the same time, and that way if you don't like the RAT you can send it back and have an instant backup. The reason for this suggestion is that my friend and I had the same complaint, without discussing it, about the mouse and our hands are very different in size.
Another suggestion would be drop the Velociraptor and just get a larger SSD, as the performance difference is very very significant.
Finally if you are going to be running at ultra high resolutions, in that 2560x1600 and higher, you might want to look at the AMD 7970. When you get into ultra high resolution you gain a huge dependence on VRAM, and the 2GB on the 680 can pose a problem at those resolutions. That extra VRAM on the AMD side can really help. The other option would be to try and find a 4GB 680, but the price premium on them isn't worth the little performance gain over the 7970.
Soo........
MB: EVGA Z68 FTW
Programs Drive: Western Digital VelociRaptor 10000RPM 600 GB Replace these two with a single larger SSD
GPU: 2x EVGA GTX 680 2GB (will add a third down the road) Replace with AMD 7970s or 4GB 680s
Keyboard: Undecided
Monitor: Undecided
EDIT: Another recommendation, if you need are getting another gaming headset, would be to get the Sennheiser PC 350's. They are amazing and work so so well with the sound card you have listed.
http://www.sennheiserusa.com/noise-cancelling-headset-computer-gamer-headset-skype-voip_502141
In fact that sound card is one of the few that can properly drive these headphones.
Thanks for the input. I currently have a cyborg rat and love it, I just want the wireless one now.
As for the Gpu's I'm a huge nvidia guy. Tried the 4870's and 6970's before. I've got my heart set on nvidia, so I'll most likely just get a pair of 4gb 680's and just not do tri sli to keep from adding too much to the cost.
I also have a thing about keeping windows on its own SSD, so I'd still have to get two drives. I just figured the velociraptor would help with the cost.
You broke it!
That works too, the 4GB models are a bit hard to find but you don't want to cripple that build with 2GBs when you are looking at the resolutions you are going for. SLi 680's will take care of you, Tri-SLi is just showing off.
Honestly, i can't come up with any problems. At this point my suggestions are more "personal preference" type of things...
I would swap the 2 TB drive with TWO 1TB drives and put them in RAID 0. I heard all these people on OCN talking about how RAID 0 can corrupt data, but from my own personal experiences it hasn't happened once yet and probably won't. Since i want TRIM support, i do my RAID array in WIndows. Even after a clean reformat of my Windows boot drive, i was able to restore the RAID 0 array on my storage drives perfectly with no data loss.
The Samsung 830 is a faster SSD than the Curical M4. Get that instead.
I have a personal preference for the ASRock Z68 PROFESSIONAL over the EVGA Z68 FTW,...but both motherboards are equally good.
A good build!
You broke it!
Originally Posted by Schmuckley View Post
For $3000 ..Y no Socket 2011 and 3930K?
Going that route only replaces a couple of components on his system, and further increases the cost for zero gain. Unless he is using heavily threaded applications, there is no point in going X79, so with that said....
OP; Is this just a gaming rig or are you doing high end visual work or lots of encoding/decoding while trying to take control of every other computer on the planet?
For a similar price you could go i7-3820 (quad core sandy-e). You'd get 40 pcie 3.0 lanes AND quad channel memory. I would think that LGA2011would make a huge difference with 2 or 3 (insane) 680s. You'd get plenty of OC headroom as well. Not sure why the 3820 doesn't get more love. Guess it's a tough case to make with a 6 core chip just $200 more...
You broke it!
The other reason is that the people who look at that segment of hardware are just going to go all out anyways, and can justify it through use.
Discussion Starter · #12 ·
Just gaming, so I'm not thinking the extra cost in a different MB/CPU will be worth my while. I know I'll spend a lot on this, but I don't care to thow away money either.
That's totally reasonable. Everyone has to pick a price point that works for them, as there is always something a little better for only $50 or $100 more. It has to end someplace. I just thought I'd throw out the quad core LGA2011 chip as it would give you the PCI bandwidth I would assume you would need with 3 680s. It would be a shame to spend $1000+ on GPUs and bottleneck yourself because you wanted to save $100 by going with LGA1155. That said, if you really only want to go with 2 cards (and don't have some work-related need for quad channel memory bandwidth), LGA2011 is a hard sell.
  • If you get a Corsair SSD, make sure it's force GT, not just Force. Here's a link. There are also a few deals right now on Crucial M4s. You can pick up a 256gb M4 for ~$200-230 right now. As someone suggested, get rid of the velociraptor completely. Not worth it.
  • With a system like that, and with your budget, I'd pick up another storage drive and use that strictly for backups. It's another $100, but with your budget, I'd like the feeling of being protected. You can grab the 2TB samsung for $100 right now.
  • For a system like this, I wouldn't trust XFX. They have mixed reviews, and there are a lot of horror stories about RMAs etc. Last thing you want is for the PSU to blow and take something else with it, then have XFX refuse to honor warranty and/or cover costs of affected components. Grab a Corsair or a Seasonic.
  • As someone recommended, I'd grab 4gb version of the card. Why not look into 670 4GB? Something like this.
  • You need to be more specific for monitors. Your 3 basic choices are: 1) 120 Hz gaming. In which case you're down to BenQ XL2420T or Samsung S27A950D. 2) 1440p gaming. In which case you're down to either Dell, HP or one of the korean monitors. or 3) 3x 1080p surround gaming. There are a lot of options in this category.
  • For keyboards, visit the mechanical keyboard club - a lot of good info there. A filco or a deck legend are two choices that (randomly) come to my head - for no specific reason. There are a ton of choices.
Really nice system. A good X79 mobo is going to be a little pricier, but I'd really consider the added PCI-E 3.0 lanes that you'd get from the i7-3820. That Evga board is one of the best Z68 boards for tri-SLI, but it's still doing more bottlenecking than their X79 board would. And you've already got 16GB of RAM in mind, why not have the ability to add some more later and make a RAM disk? It's just a more future-proof setup in my opinion. I'd also try to get a larger SSD and just skip the Raptor, but I guess that's personal preference. As for the video cards, I'd definitely wait if you have to for a 4GB card, even if you can only get one at first. You'll still be able to set up multiple monitors on these new Nvidia cards, and you'll have a feel for how many more you'll need in the future. I have 2.5GB cards and that's pushing it in 3D surround, especially in games like BF3. Good luck!
You broke it!
I am not sure why I didn't catch the XFX in there, but I can vouch for how horrid their RMA department is. Out of two RMA's I have had to deal with both were the worst experience in my life, on one video card, an 8800 GTX they flat refused to honor their warranty and it took about a month before I was able to get them to comply. They then tried to replace it with an 8500GT as they didn't have any 8800GTX in stock, trying to tell me the 8500GT was in the same performance category as the 8800GTX. Yup, like a Pinto is in the same category as a Ferrari.
/rant
On the keyboard, I can highly recommend Filco. I have their Majestouch Ninja and love it to death, amazing quality and worth every penny. If I had to do it again I would have gotten the ten keyless version, just to keep things a little more centered on my desk.
Discussion Starter · #17 ·
I'm looking into a corsair 1200 for the Psu. I'm partial to corsair, nvidia, evga and asus products.
I have a crucial m4 currently and love it, so I may just get another bigger one.
And now I find myself looking at the 2011 socket because.....well hell why not? But i cant blow my budget completely out of the water because mustang week is coming up in myrtle beach and I still have a few things I need to do to get mine ready to go.
Discussion Starter · #18 ·
I'm still unsure on a monitor setup, I'm thinking a bigger HP monitor. They don't make a bezel narrow enough to keep me happy with a surround setup.
You broke it!
You won't see a difference between the 1155 and 2011 socket with what you are doing, none at all. Unless you go Triple SLi, then you will want it for the bus.
As for display, I have never liked multiple display setups, I would just rather have one big display that the imagine is seamless on.
Discussion Starter · #20 ·
I agree with a bigger monitor.
I would do 3 way sli by the end of the year, but its more likely that I'll just build a whole new rig so maybe I'll just stick with the 1155 for a few months and build another one for Christmas.
1 - 20 of 21 Posts
