-I haven't found a proper category for "general system builds", so I'm posting it to the most relevant category I found. Please move this thread if there is a proper place for it somewhere.-
I'm planning on building a brand new system for myself sometime mid/late 2016 and I'm starting to plan everything out. This is how it looks so far:
Location: EU, but I've got no problems with buying from anywhere
Budget: 2.000$
Components:
i7-6700k (significant overclocking planned)
Gigabyte GTX980 G1
Gigabyte Z170X-UD5
Samsung 850EVO 500GB
EVGA SuperNOVA G2 750W
Kingston HyperX Fury Black 16 or 32GB 2666MHz
Usage: Games, videoediting, programing (including 3D graphics)
Two things I'm unsure about and would appreciate any advice:
1) Is it worth it to get AIO watercooling or should I go with air? Noise isn't that much of an issue, I'd like to have my system quiet, but a few additional db won't hurt. Custom loops are a bit too expensive to my taste, but I've been thinking about the H110i GT/Noctua NH-D15. Or would you recommend something completely different?
2) What case to get, depending on the cooler? I'm looking for something with good airflow options, transparent side (preferably smooth transparent material, not a mesh) and if I go with watercooling, probably a topmount option.
Comments and suggestions for other components are welcome as well!
I know there is a lot in store for this year (Pascal, Zen, etc.), so things might change drastically depending on what comes out.
Thanks!
Budget: 2.000$
Components:
Gigabyte GTX980 G1
Gigabyte Z170X-UD5
Thanks!
