Easiest way to go sub-ambient is build a WC loop and submerge the radiator in ice-water. Use a insulated cooler or even just a bucket and get a submersible pump to flow cold water through the fins in the rad. Keep adding ice as it melts.
TEC or phase is probably the next step, but buying an LN2/DICE pot is probably more noob friendly if you can buy it locally.
