1 - 9 of 9 Posts
Need a case that has a window.. and good amount of room and that can hold alot of fans for around $75-$100 ..start posting links!! ty!
Here are some fairly nice ones that are in your price range:<br />
<br />
Antec P160W<br />
<a href="http://www.newegg.com/Product/Product.asp?Item=N82E16811129173" target="_blank">http://www.newegg.com/Product/Produc...82E16811129173</a><br />
<br />
Aerocool SSP<br />
<a href="http://www.newegg.com/Product/Product.asp?Item=N82E16811196020" target="_blank">http://www.newegg.com/Product/Produc...82E16811196020</a><br />
<br />
CoolerMaster Centurion 5<br />
<a href="http://www.newegg.com/Product/Product.asp?Item=N82E16811119078" target="_blank">http://www.newegg.com/Product/Produc...82E16811119078</a><br />
CoolerMaster cases often have full-frontal grills. Great for fan modding.<br />
<br />
...Just a few.<br />
<br />
Oh! and try to get cases that support at least 1 x 120mm, preferably 2 (1 intake / 1 exhaust)
Reactions: kontemptJC
I like the coolermaster you posted...Will it hold and 700watt ocz gamestream?
<a href="http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=1215772&CatId=32" target="_blank">This</a> is what I use. It is a huge beast, has a great big window, and is ideal (at least I think so) for cable management.
Discussion Starter #5
how many fans could that hold? Is it easy to make the case hold mroe fans?
<tr>
<div>
Originally Posted by <strong>kontemptJC</strong>
</div>
<div style="font-style:italic">I like the coolermaster you posted...Will it hold and 700watt ocz gamestream?</div>
</td>
</tr>
</table>
</div>This <a href="http://www.newegg.com/Product/Product.asp?Item=N82E16817341002" target="_blank">http://www.newegg.com/Product/Produc...82E16817341002</a> should fit just fine.<br />
<br />
I believe that the width of PSU's is standard, though the length and height can vary (more so the length). Can anyone second that?<br />
<br />
If so, you will be fine. Double-check that though.
Discussion Starter #7
thanks.. rep!
Discussion Starter #8
ehh if i was to buy a p180 do they have a window'd side panel i could stick on the side or no? cuz im buying a case today at noon and im still haveing troubles.. i like alot of fans ..<br />
PPl say with the antec nine hundred its hard for wiring<br />
P180 has nothing but great reviews but no window which i want<br />
and the TT armor i was looking at looks cool but those doors might get annoying after a while what to do...what to do...
Discussion Starter #9
well I ordered the TT Armor today (black one) and now im just sittin here excited!! 3days left..
1 - 9 of 9 Posts
