1 - 18 of 18 Posts
Originally Posted by this n00b again;11946458
you make sense, hmm i was wondering the same thing too. Then i started wondering why should intel support sli over x-fire?
but here's a breakdown chart:
see image
Originally Posted by this n00b again;11954568
^^ this
but basically the pro supports x-fire and sli, the standard only supports x-fire.
pro has an intel lan controller.
^^^This and...
The 2nd PCIe x16 slot only operates at x4 in X-fire.
The Pro is x8-x8 in SLI or X-fire.
Was it unstable at lower voltages? How do you have your bios power saving features setup?
Discussion Starter · #14 ·
Originally Posted by Woundman;11976763
@this n00b again
Have you tried lowering your RAM to 1333 MHz? You might be able to achieve a higher overclock.
actually i have not tried this.
I have been trying to figure out how to get it from downclocking when not loaded.
it will down clock to 16x when not loaded.....
All Sandy bridge CPU's will downclock when not loaded to save power. I don't know if you can change it so they don't, someone correct me if I'm wrong.
1 - 18 of 18 Posts
