Table of Contents
Apr 03, 2011 Current Status
Apr 03, 2011 Parts are here
Apr 03, 2011 Painting done
Apr 04, 2011 Intake fan mod, and some WCing parts installed
Apr 05, 2011 Some fan sleeving, rad flushing, ext rad mounting
Apr 26, 2011 Custom pump mount
May 20, 2011 Done
I just got back from from a month long work trip to a computer part x-mas! This build, unlike my last build found here, will be almost mod-less. Of course, I say that now but things always change. I will do some sleeving, some painting, a custom external rad mount, and custom fan wiring. However, the only drilling I will do to the case is drill a hole for the res fill port. That is my goal, however I can almost promise extensive case modding will ensue
