i7-3930k with swiftech apogee hd
04g-p4-2686 with heatkiller waterblock
Asus Rampage IV Extreme with EK RE4 waterblock kit
4x4 GB Corsair 2133Mhz Ram 1.5V for IMC CMT16GX3M4X2133C9
180 GB Intel 520 SSD
AX1200i
2 x MCP655 with PWM
15' Tygon 3400 UV Tubing with PT Nuke and silver kill coils 1/2 ID,3/4 OD
2 x Alphacool Repack Dual Bayres 5,25" Version 2
3 x 480 Alphacool Nexxxos Monsta
12 x CFT12SB4 fans in push configuration beneath the radiators
6 x R4-S2S-124K-GP fans with filters in push/pull through the case
EG2.jpg 367k .jpg file
EG9.jpg 448k .jpg file
EG5.jpg 410k .jpg file
EG8.jpg 324k .jpg file
As you can see there is some dust and a 'shag-like' carpet with a lot of fibers so I've attempted to minimize entries for dust by having tubes enter through 3/4ID grommets placed in drilled holes in the front, effectively leaving only the radiators with fans blowing up and then the fans with filter covers as openings. (I leave the radiators covered with plastic sheet when not in operation)
Please let me know what you think and what could be done for improvement! Could use recommendations for some competitively priced high CFM fans.
AX1200i
2 x MCP655 with PWM
