1 - 6 of 6 Posts
Can someone help with setting up this Biostar Bios
Just got this system from tigerdirect
MB Biostar M7NCG 400
Ram PC3200 DDR 1024 MB 400 MHZ
CPU Sempron 3300+ 2.0 ghz
Checking into what the cpu's spec's are, the OPN gives me
volts 1.65
Level 2 cache of 512 kb
Max bus speed 400 mhz
When I set the BIOS to Optimized Defaults the system startup and when it shows the WinXP logo it shuts down with a siren warning.
With all the BIOS settings set to default the cpu is running at 1.09 ghz because the FSB Freq is at 100 mhz.
Thanks for any help you all can lend
Now I remember why I stay with ASUS auto detect
Any other info I need to add let me know.
i just ordered that barbone from tigerdirect two and i can get the sempron to run at 200fsb but thte memory gets stuck at 166mhz. the ratio is 6:5 and if i go to and change the momory speed to 200 and i get lines on my screen
dont looad the optimu=ized efaults. go to the advanced chipset config --> and chose expert not optimum and then change the fsb to 200 and for the memory leave it set to spd
Post a pic of the 'memory' and 'SPD' tabs from cpu-z.
1 - 6 of 6 Posts
