Status
Not open for further replies.
1 - 12 of 12 Posts
· Premium Member
That's pretty darn good. I use the 900w/1500VA model and it serves me well.
Originally Posted by Skullzaflare
how long does it hold your computer on?
Depends on how much power you're drawing. My 900w will keep my system running for 7 mins when folding lol. A good bit longer when idle. So this would be a bit less than mine. Plenty of time to safely shut down if the power goes out.
· Aren't this fancy!
· Premium Member
im pulling more power on gpu, but normally idling
so it would probably keep my sigrig on (3.8ghz) for 10 minutes?
if so i might "buy" one lol
· Premium Member
Yeah it'd do 10 mins idle easily.
Originally Posted by uNeec View Post
What's the point of having a 10 minute backup?
Here's a good question: Would you rather have ten minutes or none at all?
Discussion Starter · #11 ·
Really you only need like 5 minutes, or less, It will automatically shut down ur pc for you at a specified time, the backup is only their to keep your system running long enough to shut down properly and not just shut off from a power outage. 30 minutes would cost a lot more..
1 - 12 of 12 Posts
Status
