Should be fine. I would go with the HIS instead because it has a bigger fan which in general means less noise.Originally Posted by paul-fs
I want to buy this: http://www.mindfactory.de/product_info.php/info/p823402_1024MB-XFX-Radeon-HD-7750-Core-Edition-Aktiv-PCIe-3-0-x16--Retail-.html card. will my psu be strong enough (350 W) and will it fit on my mainboard and work with it?
Tanks
It's up to you, if you're after silence go for the HIS.Originally Posted by Rx14
http://www3.anobo.de/pc-und-hard-software/pc-komponenten/grafikkarten/ati/pci-express/1024-mb/5905/his-hd-7750-icooler-gddr5-1024mb-dp/dvi/hdmi this seems cheaper including postage but http://www.testsieger.de/testberichte/club-3d-radeon-hd-7750-1-gb.html?o=gp this seems cheaper overall. Does the Club3D one run hot (and noisy) because it is single slot?
