1 - 4 of 4 Posts
Still kinda lost
So i am a n00b with monitors i need some help!so as i know its like this:
1-120Hz or 2560x1440p
2-matte or glossy
3-IPS or LCD
4-16:9 or 16:10
5-low ms or high ms
So i want this monitor for gaming so which one to pick? and why can some one please detail it for me and thank you!
The budget will be under 400$
Just to start off, your budget is way too low for a 2560X1440 monitor so thats out of the question. 120HZ isnt really worth it unless you want 3D so i wouldnt consider buying a 120hz if i was you. Matte vs Glossy depends on your preferences but most come with Matte (which can be a good thing if you want to avoid glare as much as possible). Now IPS vs LCD: i would say dont depend a lot on it because colors depend more on the quality of the display than the technology. 16:9 vs 16:10 : 16:9 without a doubt (latest and most popular aspect ratio). Low ms vs high ms : lowest possible is best but nothing from 5ms and under makes a difference.
now for displays:
1. http://www.newegg.com/Product/Product.aspx?Item=N82E16824236309 (ASUS 27 inch 1080p IPS 5ms LED) for 350$
2. http://www.newegg.com/Product/Product.aspx?Item=N82E16824005369 (LG 27 inch 1080p non-IPS 5ms LED) for 290$ i own the 24 inch version and its an excellent monitor
Still kinda lost
Thank you very much for the replay,but when i mentioned the 2560x1440 i meant the Korean IPS and they are in fact under 400,So i wanted some one who knows their models to help me know which one is the best!
Still kinda lost
So do any one know which seller sells a guaranteed (No dead pixel ) Korean IPS and which one is the best model and what is the difference between the normal and the tempered glass?
1 - 4 of 4 Posts
