Buying a Silverstone FT02 Case:... Questions
2569 Views 23 Replies 12 Participants Last post by  Eduardv
Hello Guys
I am interested in Buying a Silverstone FT02 case
I need to know several things:
1. Will this case come equipped with the Air Penetrators Ap181 fans?
2. If it doesen´t come with the Air Penetrator fans, can the normal fans be removed and replaced by the Air penetrators?
3. What other differences does it have against the Rv02 apart from the fans.
Looking forward for your responses,i i'll give +rep to all
Thank you.
1 - 20 of 24 Posts
1. Tengo entendido que no todas vienen con AP181s, sólo ciertas "revisiones" y eso ya depende de la suerte, porque por lo general no puedes decidir sobre eso al comprar en los lugares de siempre (Newegg, Amazon, etc..)
2. SÃ*. En la raven (y por supuesto, en la fortress) y en cualquier otra caja asÃ* sea la más mala de todas, los ventiladores no están fijos...perfectamente se pueden reemplazar.
3. a) Los materiales usados en la caja FT02 son metales (aluminio y acero), mientras que la raven utiliza plástico y acero; b) La FT02 viene con un material de absorción de ruido en las paredes; c) La más obvia, la forma exterior, porque el diseño interior y la refrigeración, son lo mismo.
1) If you're buying it new, yes.
2) Yes. You'd just have to find a place to buy penetrators.
3) The FT02 is a unibody case with 5 built-in HDD racks. I think the top mesh is also friendlier.
Looking at the pictures of the case on newegg it doesn't look like it comes with the penetrator fans. It looks like ti has the regular 180mm with a silverstone adapter on it to focus the airflow. http://www.newegg.com/Product/Produc...82E16811999217
Now I'm sure you can swap them out for the penetrator fans as they are all 180mm. http://www.newegg.com/Product/Produc...82E16835220039
The major difference on the inside is the HDD bays. The FT02 has in my opinion a much better system for mounting the HDDs. All else on the inside is about the same and on the outside, well the difference is obvious.
Hope that all helped.
BTW i have 4 of the 180mm penetrator fans and they are great!.
Originally Posted by Machiyariko;13030487
Looking at the pictures of the case on newegg it doesn't look like it comes with the penetrator fans. It looks like ti has the regular 180mm with a silverstone adapter on it to focus the airflow. http://www.newegg.com/Product/Product.aspx?Item=N82E16811999217
Now I'm sure you can swap them out for the penetrator fans as they are all 180mm. http://www.newegg.com/Product/Product.aspx?Item=N82E16835220039
Silverstone replaced their originals stock with the Penetrators. If the case is new, it will have Penetrators.
All good, I was going by the Newegg pics as well as a few others.
If it comes with them then all is well. Lots of added value for that case if they include 3 of them.
Silverstone includes the Air Penetrators in all their new FT02s. Pisses off some of the older owners but what can you do, progress is good. Between those cases I like the FT02 look myself. Best air cooling case available.
Yes, yes, like the other people said...the hard drive bay is different. Make sure you get the new revision for the penetrator fans!
Thanks guys.
Whats the best chance to get the new revision.
Amazon or Newegg.
Thanks
amazon. Be aware that they are planning to update the ports to usb 3.0. You will be able to buy it separately also.
Originally Posted by Eduardv;13031110
Thanks guys.
Amazon or Newegg.
Thanks
Amazon, they don't keep a lot of stock in storage. They usually make enough orders with the manufacturer to keep up with the demand.
Thanks
+rep
if you order thru amazon dont use the free supersaver shipping, i made that mistake ended up canceling my order for the windowed version due to them selling out prior to my order getting shipped, got the non windowed version in 5 days using normal shipping .
Using normal shipping instead of free super saver shipping won't make a difference. I used Amazon Prime (2 day) shipping and then Amazon told me my Azza case was back ordered for a 2-3 weeks.
Best case for Air, worst case for Water. Just saying.
The FT02 also comes with sound deadening foam.
The new RV02s all come with the FT02 interior.
The old RV02s had the crappy HDD cage and an extra PCI expansion slot
Yeah no problem,i don't water cool.
Yes they have the same interior.
1 - 20 of 24 Posts
