buying and overclocking amd phenom 9850 2.5ghz
1107 Views 12 Replies 8 Participants Last post by  Kratthew D. Kraids
hey guys how u doing ? u already know my system , i was thinking in buying a new processor : the amd phenom 9850 what do u think about this ship??
1 - 13 of 13 Posts
It's ok. You can pick up a Phenom II X3 for near enough the same price.
I agree, don't go anything less than the PhenomII 720BE. It's a tri core, but it's faster than it's quad core predecessor
Thats if your board supports it.
agree. and you'll get better performance, and more overclockability too. first day i had mine i got it to 3.994, 4's a no go though
what motherboard u recommend guys to buy for phenom II set up?
I would recommend The Biostar TPower N750, Newegg no longer sells this board and Tiger direct never carried it but this random site I found sells it. Right now they are out of stock but here's the link, on Newegg it was 160 this site sells it for 50 dollars less
http://rickspcparts.com/catalog/prod...oducts_id=4411
Ditch the 9850, it's old tech. As already stated go for at least PhenomII X3, and try to unlock it with the Gigabyte board (Don't know the exact model). If you don't know, if you get a certain X3 and the GB Motherboard, you can unlock the 4th locked core in the X3, giving you a Phenom X4
I'll fetch the link, give me a second.
Here you go.
http://my.ocworkbench.com/2009/amd/A...and-X3-720.htm
Any board that has an ACC (Advanced Clock Calibration) option I believe can unlock the 4th core
True, the motherboard must have ACC, and AMD 790GX + SB 700 for the 4th core to unlock correctly.
So it needs to be that specific SB otherwise you get a shortbus 4th core?
it needs the SB750, not the SB700 as the 700 does not have ACC
I think any X3 is a shortbus x4 even if the 4th core does unlock.
I know a handful of people who have gotten a stable fourth core, although I'm sure just a handful isn't enough to justify unlocking it
1 - 13 of 13 Posts
