1 - 6 of 6 Posts
http://www.mostlydigital.ca/product/H155307
AS3820TG-6829 W7HP64B ENG/FR Corei5-480M(3M L3 cache,2.66G,35W)4G(2/2)DDR3 500G
Manufacturer: Acer
Manufacturer Part Number: LX.RAC02.041
Category: Computer System - Notebook - System
Catalog Number: H155307
CAD $794.99
Add to Cart
The Aspire Series offers a diverse range of notebooks that give you the performance, graphics and communication tools to step up your digital entertainment, complete your daily computing tasks, and stay in touch with everyone you know, whether you're at home or away
Primary Information Processor Type Core i5
Processor Manufacturer Intel
Processor Clock Speed 2.66 GHz
Hard Drive Capacity 500 GB
Input Device Type Keyboard; Touchpad
Header / Model Aspire 3820T
Features webcam, Kensington Lock Slot, BIOS Passwords :User, Administrator, Hard Drive
Laptop System Type Notebook
Mainboard Chipset Type Intel HM55 Express
Display Display Diagonal Size 13.3 Inch
Display Technology TFT Active Matrix
Max Resolution 1366 x 768
Memory Cache Memory Type L3 cache
Cache Memory Installed Size 3 MB
RAM Installed Size 4 GB
RAM / Installed Qty 2
RAM Max Supported Size 4 GB
RAM Technology DDR3 SDRAM
Storage Storage Controller Type Serial ATA
Processor Processor Number 480M
Dimensions&Miscellaneous Width 822.96 Cm
Depth 596.90 Cm
Height 73.40 Cm
Weight 1.80 Kg
Interfaces VGA; HDMI; USB 2.0; Headphone; Microphone
Video Graphics Controller AMD Radeon HD 6550M
Video Memory Installed Size 1 GB
Audio Audio Input Type Microphone
Audio Output Sound card
Networking Networking Type Network adapter
Data Link Protocol Ethernet; Bluetooth; Fast Ethernet; Gigabit Ethernet; IEEE 802.11 b/g/n
Power/Battery Battery Technology Lithium ion
Battery / Number of Cells 6-Cell
Battery / Run Time 8 Hour
Power Device Type AC Adapters
Software Operating System Microsoft Windows 7 Home Premium 64-bit
Service&Support Service & Support Type One-year limited warranty
UNSPSC Code UNSPSC Code 43211503
sounds perfectly fine go for it, with a i5 you wont be dissapointed
Im not a fan of Acer myself, but Im sure all Manufacturer's have cheap & good builds.
You can save yourself $75 bucks by going through NCIX
http://ncix.com/products/?sku=58434
learn to use shopbot.ca
I just picked up a i3 Toshiba for my wife and its awesome, I can imagine an i5 with decent GPU in it will be a sweet system.
Originally Posted by tranman;13044789
thats actually a very nice laptop but you can get it cheaper elsewhere. Also, the 3830t are coming out soon with the sandy bridge processors. you might want to wait and look into that. newegg has it for 529 free shipping.
http://www.newegg.com/Product/Product.aspx?Item=N82E16834115977&cm_re=3820t-_-34-115-977-_-Product
Bro, that is the i3 380m model - NOT THE i5 480. The best price you can get on the I5 model is at NCIX right now.
1 - 6 of 6 Posts
