Gigabyte MA-790XT-UD4P = 860 EGP
Gigabyte MA-790FXT-UD5P = 1125 EGP
Either of those 2 boards. But if you're going to be using 2 video cards (or more) than the UD5P is the better choice. I was going to get that board until MSI came out with the 790FX-GD70. It has 2 full size PCI slots and 4 PCIe slots. And I liked the color scheme of the MSI board a lot more.
As for the CPU, what's your rig going to be used for? Primarily gaming? If so, then the 720BE is your best bet because of the L3 cache. I know you said you were going to try and unlock the L3 on the Athlon, you can't rely on that. Your expectation when buying any CPU that has locked components, whether it be a core or the L3, is that it WILL NOT unlock successfully. Don't get me wrong, if it does that's really awesome, but if it doesn't no loss.
But if you're going to be encoding I'd imagine that the extra core of the 620/630 would be more beneficial. However, I don't know how well the Athlons overclock. If they don't overclock well, then they lose their advantage.
