I just read a review on the 5970 where it stated this chip simply matched the performance of the old sideport.
PLX PCI Express Switch Enables Blinding Speed on New ATI Radeon Flagship Graphics Card SUNNYVALE, Calif.--(BUSINESS WIRE)--PLX Technology, Inc. (NASDAQ ![]() “The ATI Radeon HD 5970 graphics card, supported by the PLX® PEX 8647, exemplifies top performance for today’s extreme computer games,†said Rick Bergman, senior vice president and general manager, AMD. “AMD chose the PLX chip for its industry-leading features, allowing very high-speed communication between our two powerful, next-generation Radeon graphics processors. The PEX 8647 switch has provided enhanced flexibility and performance in our HD 5970 design and enables AMD, and its partners, to provide customers the fastest graphics solutions on the planet.†“High-end graphics controllers and cards need high-end IO so their data can move from chip to chip, card, system, and screen,†said Shane Rau, PC semiconductor research director at IDC. “PCI Express 2.0 is now the leading-edge IO standard for all high-end graphics cards in the PC market and compatibility with it is essential for market leadership.†The PLX ExpressLane™ PEX 8647 switch is specifically designed for the cutting-edge graphics industry. The PEX 8647 is a 48-lane, three-port, PCI Express Gen 2 (5.0 GT/s)-compliant switch featuring... |
Originally Posted by Interview with Dave Baumann A reader question: I had a user question asking, what happened to Sideport (XSP)? Sideport was intended to add more interconnect bandwidth. It has been disabled ever since the release of the RV770 (X2) from day 1. We heard that "that much bandwidth is not needed". IMO... you can never have enough bandwidth really. What was going on there? This is simply a case of our software capabilities catching up to our hardware capabilities. When the initial design of the RV770 was taking place and concepts such as Sideport were being kicked around our ATI CrossFireX™ software wasn't in the place it is right now, so there was a much higher reliance on inter-chip communication. While having lots of bandwidth is rarely a bad thing, the ATI CrossFireX communication bandwidth between two discrete cards is less than local bandwidth - even though Sideport doubles the inter-GPU communication bandwidth on an X2 type solution it's still not significant enough to really change the disparity in local frame buffer and inter-GPU bandwidths. The software work that occurred in the space of time between the RV770 design and product saw significant improvements in inter-GPU communication. Internal to the driver we now have a number of "alternate frame rendering" (AFR) profiles, with many parameters that can be tweaked in order to control how the rendering behaves over multiple GPU's and reduce the inter-GPU communication as much as possible. By the time we put two RV770's on a board and started testing Sideport, the current ATI CrossFireX software capabilities delivered more than enough bandwidth, obviating the need for Sideport. |
