1 - 9 of 9 Posts
I cannot get this to compile and have been trying to figure it out for almost an hour... its driving me nuts... please tell me what im doing wrong
 switch (choice)
        case 'y' or 'Y':
             again = 1;
             break;
        case 'n' or 'N':
             again = 0;
             break;
        default:
                oops=1;
                cout << "Please enter a valid option" <<endl;
                break;
Originally Posted by Jacka
switch (choice){
        case 'y':
        case 'Y':
             again = 1;
             break;
        case 'n':
        case 'N':
             again = 0;
             break;
        default:
                oops=1;
                break;
wow im speshul! thanks lol rep+ i cant beleive i couldnt find that anywhere... i guess i was looking in the wrong places....
Just so you know this would be the correct use of or.. personally I'd just use
choice = toupper(choice); Then only need to use caps, it helps save typing when you have a bunch of switch statements.
switch (choice)
case 'y' || 'Y':
again = 1;
break;
case 'n' || 'N':
again = 0;
break;
default:
oops=1;
break;
I think he's just saying double pipe || is the proper "or" operator such as in if statements.
And I also agree that converting everything to a common case is easier than having multiple statements for each character.
Discussion Starter #7
And how would you go about doing that?
Just like SevasTra said, toupper( char ); or tolower( char );
So before the switch block, use that to convert whatever input the user gives and then you don't need to worry about the case you're converting away from.
This doesn't change the fact that using a || like that won't compile. You cannot do it, the fact that || is the or operator in C is beside the point.
1 - 9 of 9 Posts
