1 - 20 of 28 Posts
Let go!
Put the case onto the Carbon vinyl
Cut everything out
Stick it!
Thnks to L3P i had some black assortiment of inbusses :rock:
Finished!
Tried something original with the Window panel
Better pics in Daylight.
Bought some random hardware
New:
OCZ OCZSSD2-2VTXE120G, voor die 60 euro
Used
Mobo en Cpu
Asus Rog maximus 3
Intel 875K
scaled.php?server=217&filename=p1040184q.jpg&res=landing
Carbonize the cpu block till i can afford a identical plexi one
mobo with memory build:)
Testfit in the case, getting cramped already
I have some little room left
With sidepanel
positioned the Dual pump and drilled the holes for it.
Bought at my local plumber store 2 metre of acrylic tubing.
First try:)
My working bench
Heat it up, hold it inplace, take a sprint to kitchen and cool it down, mission succesfull!
Bp C47 where in the mail, gladly
Same as the SSD!
Prepared the tubing for the fittings, Just like Kier does, grind a 8mm edge.
Then i used speedhack! lol, i forgt to make shots of the buildup progress
I dont have budget for the sleeving, maybe next month
Because there is no room between panel and mobotray, i need to route everything between the mobo and the mobopanel, but it worked
Some what clearer pics taken with a handycam
not allot of tekst, just better pics
Did some random sleeving, put 24/gpu extenders, black SATA cable and much better cablemanagement
Also did a boot
Soo, its quite done now, The system is up and running smoothly after some flaws,
First, because the solid tubing didnt expand to pick up the pressure what was left behind when u turn the system off i had some minor leaks, after a little chat Peter(l3p) came with an idea, that was to make a kind of balance line of 1/2tubing, so i made it like he suggested, and damn it worked, was a miracle! its running real smoothly now, Gladly
Piics
Awesome! Looking great, really. Never thought about acrylic tubing bent like that, and the carbon fiber vinyl makes the case look awesome .
However I don't understand something, why don't you put tubbing like this:
Anyway, looks awesome! Maybe if you had a res outside it would show off more but anyway, it's fantastic
I like the build it looks really nice. Explain more of what you had to do to stop the leaks because i wasn't really sure what you meant on your last post.
So basicly i connected a 50cm piece of tygon 1/2 tubing, used that ass fill and bleed port(connected to highest reservoir port) and that sorted my pressure fails.
Acrylic tubing can not expand to pressure into the loop i had with 2 mcp355 pumps, after ataching the tygon tybing i had that sorted.
Loving it (apart for the weird reservoir). I've never liked the copper/nickel tubing. Acrylic tubing though looks perfect Oo. I'm guessing that with acrylic tubing you'll see your coolant as well as in the reservoir, that you won't ever have plasticizing issues, that the tubing won't change colour... that's really the dream tubing. Well it looked like the dream tubing until you mentioned having had leaks because of pressure. I'm not sure I understand the pression / tygon thing by the way.
Oh, almost forgot, how much did the tubing cost and what case was that ?
Good question.
EDIT: What did you cut the acrylic with and how did you get the right length ?
Discussion Starter · #8 ·
The tubing costs 10 euro for 2 meter.
I choose this route to get 2 long straight lines because i tried both options but liked this one more.
Here some pics
The 2 trouble makers
When spinning up no problems at all
but when u turn them off The fluids stops, u create a vacuum pressure something ish
The Line that can take all the pressure and fill line and bleed line
I hope it wil be clearer about that
I made the line rougly inshape, them measure everything, and cut in with 5mm each time
i cut it with a angle saw
That's really cheap Oo.
Makes you wonder why nobody uses it. I know I will, even if it's only in a year. But I will.
How comes that pressure thing doesn't happen with copper/nickel tubing if it's caused by the acrylic not being able to stretch ?
(I haven't read a lot of hard tubing work logs so I might be wrong about that)
That line is really well hidden. If you hadn't shown us pics of it I don't think I would've noticed it. Good job on that
That saw looks pretty confusing
Because u need to File the Acrilyc tubing to 12mm and copper plumbers piping is 12mm from origin! so u have no weak spots ^^
And this loop is only 300ML With 2x mcp355 can u imagine
Oo 300mL for CPU+GPU+2xmcp355+reservoir+360 rad ?
With 8mm ID clearflex60 tubing my loop needs an entire liter (1000mL). You really sure about yours only needing 300mL ? What's that reservoir's size ? Mine's a 250mL one and I've got two 55mm thick 280mm rads (but no GPU block). Lets say that your res is 50mL and your single 360 drinks about the same amount as one of my 280s. That'd make yours 800mL minus the rad. I've no idea how much mL a full rad contains, I'm guessing it's a lot, maybe 300mL which would mean my CPU block, pump and all the tubing needs 150mL. Does that sound about right ?
If those values are right then your loop (lets say a GPU=50mL, again, I've no idea what it really does) would be at least 500mL. And my values are most likely wrong so that makes 300mL really not much.
Oh, here's mine btw (those are the "old" smartphone pictures, I'm still looking for a good guide on taking photos of PCs, then I'll borrow my sister's camera):
Discussion Starter · #12 ·
This is a magicool 360 rad, holds up to 100/150ml fluids
res around 50/75
My reservoir can fit 5 times less fluids then your res xD! And magicool rad is like 2.5cm thick like a normal fan
So Nah, u cant compare that
Discussion Starter · #14 ·
Rad: allrount temps are 23 degrees (roomtemp ) with 3 tfc triebs 1650 rpm @ 1000 rpm daily.
Pumps: there my pink phantom build pumps, and because i can xD
Discussion Starter · #19 ·
Originally Posted by willywill View Post
This is one crazy build, you got my vote on build of November or should i say for 2012.
Nice profile picture
Spoon Sports
Originally Posted by WebsterXC View Post
Epic CPU block is epic. Please don't replace it...
Haha thanks thanks
1 - 20 of 28 Posts
