1 - 6 of 6 Posts
Even though I love to help. And am more than happy to give assistance to anyone who need's help with learning C++ or just have questions for class. Or need a program made, if you are curious where I learned my basics I will share with you.
http://cplusplus.com/doc/tutorial/
I suggest though you look more than even there. Here is one thing also, I would like other people who have learned c++ on there own to add other sites.
Overclockiit
Nice tuturial, how long have you been coding?
On building compilers or compiling binary or just running the compiling command or well be more descriptive on what you are asking. I can't give you a full answer sorry.
Discussion Starter · #6 ·
Alright for all you people who want more than just C++.
PHP tutorial
http://us2.php.net/tut.php
Java Tutorial
http://sepwww.stanford.edu/sep/josman/oop/oop1.htm
Perl Tutorial
http://www.comp.leeds.ac.uk/Perl/start.html
Everything about MySQL
http://dev.mysql.com/doc/mysql/en/Tutorial.html
Combining MySQL and PHP
http://www.freewebmasterhelp.com/tutorials/phpmysql
C (stand alone) Tutorial
http://www.its.strath.ac.uk/courses/c/
TCP/IP Programing Tutorial
http://www.catalyst.com/support/tutorials/tcpintro/
Visual Basic (disgusting)
http://www.vbtutor.net/vbtutor.html
My suggestion for people out there just starting go with VB (Visual Basic) I was looking for some good ol QBasic links but all my old ones are dead.
Compilers:
to run and see php and MySQL get apache from www.apache.org/
for c++ I suggest either a unix, linux, Visual Studio's 6(VS6) (not .net even though company's are moving to it I dislike it's frame work). If you can't find VS6 then get KDevelop www.kdevelop.org/
Java http://www.thefreecountry.com/progra...avatools.shtml
Really you want to know an operating system that has the built on board (compilers/builders) and don't cost you a dime and are easy to use. Unlike MSWXP (Microsoft Windows XP). UNIX which is free and the ISO's can be found at freebsd.org. They even make a 64bit version.
1 - 6 of 6 Posts
