1 - 11 of 11 Posts
Dude, get the Tuniq Tower it rocks.........check it
9 Cans of Ravioli
Should.
But your RAM makes me cry.
Nice overclock, but you should be able to tighten RAM timings to 4-4-4-12, since they are only running DDR2 740.
I would estimate a BT might drop temps 2C, and if you change out the stock 54CFM fan for a 100CFM+ fan than another 2C. (Total: ~4C drop)
But if I were you I'd keep the Arctic Freezer 7 Pro until/if you decide to go into watercooling or better.
Stick with one temp monitor.
Having more than one can screw up the readings, some knowledable guy on here told me that.
TAT's good and so is the Asus Probe or AI Suite
Thats Orthos Beta.
I thought all Orthos ran 2 instance in one program
could be
1 - 11 of 11 Posts
