1 - 5 of 5 Posts
I recently bought some CableMod cable combs from Performance-PCs to use with my black/gold sleeved extensions from Silverstone, after reading some Amazon reviews that stated they were compatible. To my dismay, the sleeved wires did not fit at all, and in trying to squeeze them in, I ended up snapping the bits off one of them.
Performance-PCs is pretty strict with how they refund money, and they practically robbed me for shipping, so I'm trying to look elsewhere, in the event that I have to return something again.
There are user images of cable combs being used with these extensions, so I'm wondering where else I can get ones that are compatible. This time, the combs definitely have to fit slightly thicker cables, and I would prefer they are made of something more flexible, like a rubber/TPU solution.
TL;DR: Need help finding better cable combs. Any suggestions? Image enclosed for reference.
Had the exact same cable combs from CableMod which I also ordered from performance pc's. I've only had one comb break so far.
Not really offering a solution just stating my experience.
And aren't you supposed to take off the black sticker if they're meant to be clear?
I'm not using CableMod's cables. The issue was not with the cable combs breaking, it was that they aren't compatible with the sleeved extensions I use, and I want to find cable combs that are.
These are black cable combs.
PPCs is nothing but a bunch of guys trying to take advantage of PC builders by marking up stuff you cannot get anywhere else.
"Shipped from PPCs to one state over thatll be $50"
Discussion Starter #5
Yep. Never really had a problem before, but after this, it's clear they're run on stingy-ass principles. Shipping is expensive as hell and any returns are deducted 20% for a "restocking fee" on top of the cost of shipping it back to them. The fee is waived if you are refunded in store credit, but you'd still lose more money because you have to pay for the shipping again.
Definitely avoiding business with them whenever possible from now on.
1 - 5 of 5 Posts
