I have a Seasonic Focus+ Gold 650w. I want to buy the following product:
https://cablemod.com/product/cablemod-basic-modflex-cable-extension-kit-dual-62-pin-series-red/
My 1080 Ti requires one 8 pin and one 6 pin power connection. The original cable from Seasonic itself which connects to the GPU splits into two cables and each of the cables is 6+2. So, there is no problem. All is good. The problem is the product picture. If you examine the picture carefully, the PCI-E cables seem to be 8pin with no separation/split. That means I won't be able to connect one of them to my GPU. The product description says the cablemod product has 2 x 6+2 pin PCI-e cable. If this is the case, then I should not worry at all. Which one should I trust: the picture or the description? Or maybe I shouldn't trust my eyes, or?
