Cable modem pci card from server
1201 3
Im curious rather than using my external cable modem and router could i use
<--- the one i have has the network plug also.
Would this put me at more of a risk for virus's and such. Would my adelphia isp work with it? Could i just hook up my cable line to it and have the internet!?
helps good thx!
http://www.networklab.co.uk/cmodem/nics.html
1 - 4 of 4 Posts
You would have to check with your ISP -- they're usually pretty picky about what you can connect to their service with so chances are the answer is no.
EDIT:
That's not a cable modem... It's a network card for an outdated 10mbsp (packet relay *) network that used coaxial line with terminator ends.
* Packet Relay networks were so slow because the data had to pass through every computer on the network until it found the terminal it was meant to go to.
ya that card is soo outdated...lol like a decade or so... and no it wont work for internet, u have to run the cable into a modem first, then to your network card...
1 - 4 of 4 Posts
