Just got my cables today from cablemod, spent 326.90$ And then I got this cablemess.
Is this normal? I always heard good things and then got this crap. 3 of 12 cables are pretty bad. honestly not sure if I even want to use the 24pin. it looks so aweful and because my case is a 380t it will be super visable as the mess starts in the middle of the damn cable. Like they didnt even try to do it close to the one end. I can live with the 6 and 8 pin but those also have a wonder tangle.
Minor issue is all cables are over-sized random amounts 10-45mm which isnt the worse thing but still annoying when you're in an itx case where You already oversized a cable cause they default to 50mm increments. example: I wanted 260mm for my motherboard cable, went over to 300mm because I cant go under an then that cable is an extra 30mm in addition to that. I wouldnt nitpick this though if all my cables were at least done right.
Let me know what you think. Am I rightly upset? I dont know, I spent so much on these cables I just figured I would get what I paid for.
