1 - 5 of 5 Posts
These are my steps (Please do the problem, but also tell me where my mistake was):
Step 1: Deriv of curve
y'=3x^2
Step 2: Slope of Parallel line
m=12
Step 3: Plug 12 into y' for slope
12=3x^2
x= 2,-2
Step 4: Plug 2 into Original Equation to get points.
y(2)=1+8
y(2)=9
y(-2)=1-8
y(-2)=-7
Points= (2,9);(-2,-7)
Step 5: Plug points into y=mx+B equation with m=12 to get the equation of the lines tangent to y=1+x^3 but parallel to 12x-y
9=12(2)-1+b
9=24-1+b
b=-14
-7=12(-2)+b
b=-31
Step 6: Write equations of the lines because I found b.
y=12x-14 and y=12x-31
Made a mistake, ignore my previous post
Also, image doesn't work
Again, mistake is in step 5
9=12(2)-1+b
9=24-1+b
b=-14
-7=12(-2)+b
b=-31
So you want the equations of the line in the form y = mx + b
You don't actually need that -1
Ends up with b = -15
You messed up the signs here
So you have -7 = -24 + b
You end up with 17 = b
1 - 5 of 5 Posts
