Call of Duty 4 : Modern Warfare Patching?
255 Views 7 Replies 7 Participants Last post by  Hayday
My friend says this game is supposed to auto-patch itself. However i have hit the issue of this... not working. I can't find an index of patches to manually patch with and i can't find any update button in the game. Anyone know how i can get it up to 1.7? I'm totally lost.
1 - 8 of 8 Posts
Just download this then this and you're patched up.
I don't think it auto patches.
the auto patch seemed to break after 1.5,make sure you get every patch if you go on servers that use the xmas crash map,iirc the 1.4-1.5 is the patch that contains that map
Sounds good. Will REP+ upon success.
Download the 1.6 patch, than download the 1.7 patch.
1.6 & 1.7 as mentioned before.
Steam does patch itself to the latest version tho, It did to me
http://www.gamespot.com/pc/action/ca...tabs;downloads
There ya go in case you don't like the look of the others
1 - 8 of 8 Posts
