Call of duty world at war for pc profile backup?
8612 Views 2 Replies 2 Participants Last post by  SiX767
Where do i find player profiles to back them up?
I can find them in call of duty4 but there not the same as world at war.
Plz help thx
1 - 3 of 3 Posts
Here ya go!
*** Manually back up your Profile ***
Below are instructions for manually saving player profile:
To backup the save and profile data for you Call of Duty: World at War you'll need to do the following:
*** Windows Vista ***
Open the games browser (start -> games)
Right click on the entry for Call of Duty - World at War and select saved games
Backup the players folder
Or if the game is not in your games launcher or you cannot locate the games launcher do the following:
First you need to setup your system to see hidden files and folders in Vista:
Click on the Start Menu
Select Control Panel
Double-click on the Folder options
Select the View tab
Select the option to view hidden files and folders
Next browse to the data you wish to backup:
Go to start -> computer
Double-click on C:
Double-click on the users folder
Double-click on a folder that has your Windows username
Double-click on the AppData folder
Double-click on the Local folder
Double-click on the Activision folder
Double-click on the CoDWaW folder
Backup the Players folder and servercache.dat file to a safe location
*** Windows XP ***
First make sure you can see your hidden files and folders in XP:
Click "My Computer". At the top of this window click "Tools" then "Folder Options".
Click the "View" tab, then "Files and Folders" then "Hidden files and folders".
Now check the one marked "Show hidden files and folders".
Now Click "Apply" then "Okay" at the bottom of this window.
Go to My Computer
Double-click on C:
Double-click on the Documents and Settings folder
Double-click on the folder the has your Windows username
Double-click on the Local Settings folder
Double-click on the Application Data folder
1 - 3 of 3 Posts
