1 - 3 of 3 Posts
I have CoD4 installed on my windows vista 64 bit partition. I currently use my windows 7 partition because vista won't load. (it stays at a black screen.) I lost the retail box with the key so is there any way to transfer my activated version from vista to win7? The ideal solution would be to get vista working but I don't know how without my backup cd. *sigh* Thank you in advance.
If Vista isn't working, then delete the Window 7 partition, put in your Windows 7 CD, then use the Upgrade option for Vista to upgrade to Windows 7. It will keep your programs and data in-tact without needing to reinstall everything.
1 - 3 of 3 Posts
