Does anyone know how to put together the 1080 Nova + the Box + Shroud?? Sounds easy enough. I don't know how to fit it in or on there as theres ZERO instructions so that the tubing for water comes out. So confusing!
I'm referring to http://www.frozencpu.com/products/18382/ex-rad-484/Phobya_G-Changer_XTREME_Nova_1080_Full_Copper_Radiator_-_60mm.html?id=MnEv9Io2&mv_pc=322
and this box http://www.frozencpu.com/products/14966/ex-rad-338/Phobya_Nova_1080_External_Radiator_Box_-_Black_Powder_Coat_38282.html?id=MnEv9Io2&mv_pc=377
There's not enough room to sit your rad inside of the box with barbs or compressions on it so I'm totally confused. The spacing in the box is also not wide enough for the rads + 25mm fans.... Totally confused.
