Originally Posted by simonsez
Can I flash my ATI 9600 PRO r350 to an XT? If yes, where would I find the flash? I'm new to OC. Just got my Artic Rev. 3 and installed it.
Should I run ATI Tool to see my highest core setting before flashing my card? What core setting is reasonable before flashing my card?
Sorry for the multiple questions. Thanks in advance.
I dont think the 350 core can be flashed to a XT as the XT have 360 core. I think there are two versions of PRO (one with 128 Mb and one with 256MB) The 256 MB ones (most of them) seem to have a 360 core and if you have the same then you might be able to flash it. Keep in mind, I have read reviews that there is no good use to flashing it to an XT. Rather use ATI tool or Radclocker to overclock your card...thats all you need to boost performance.
I have also heard about people flashing their cards and render them useless...Make sure you back up the old bios first and if your display card doesnt work after the flashing process (followed by reboot), use a PCI display card to boot up and restore it back....
Check this website for Overclocking/Flashing tools and BIOS
http://www.techpowerup.com/bios/
