A big enough chiller can keep your liquid temp at 20°C, or whatever you want forever (too low is hard, but down to -10°C isn't too bad). It would be expensive, use a lot of power, and output a lot of heat, but it can do it. Generally I would recommend not using radiators with a chiller unless you were targeting above ambient liquid temperatures.
I am not sure what you mean by "keep water temp at 20°C instantly"?
