1 - 1 of 1 Posts
i7 8700k 5.0GHZ
32gb DDR4 3200
1080TI Extreme
Z370 Extreme 4 mobo
860 SSD
my cooler is NH D15, 2 fans 2 rads
I did an initial 5.0ghz set at 1.35 volts. Here is what I am getting from cpu-z, and hwmonitor, could a seasoned eye look at this and tell me if I should back the voltage down. I saved up for this computer and want to make sure i take care of it. I can order contained water cooler for the cpu as well but I am wanting to see how this d15 handles.
I am now at 5.0ghz, at 1.32 volts
prime95 spiked my temp to 90 at 5.0ghz/1.35 volts, its why I dropped the voltage down. I plan on ordering a liquid cpu cooler tonight
I did get a windows freeze earlier, maybe too low voltage?
https://ibb.co/kPspbc
Thanks in advance!
1 - 1 of 1 Posts
