1 - 11 of 11 Posts
can anybody confirm Phenom 2 x2 550BE working on Asus m2n32 ws pro?
im wondering if anyone knows becouse i will buy this cpu but im not sure will it work or no ? infact every AM3 cpu can be run on Am2 socket but my mobo has no bios from 2008 y. im with bios 2001 its latest. thanks in advance
i dont think it can... i think it stops at the am2+ chips, not sure.
Discussion Starter #4
im realy disapointed from asus
no bios update from 2008. i love my mobo its perfect and i want some new cpu for it
M2N Fan
Discussion Starter #6
yeah i saw it but its not phenom 2 ? it is not a guarantee . here is the table:
M2N32 WS Pro
DrSwizz1802Sempron 1404105.17 MHz45wValidation
DrSwizz1802Athlon II X2 2403569.93 MHz65wValidation
Kaputto1802Ph II X4 9403494.87 MHz125wValidation
M2N Fan
Well the Ph II x2 is a cut down Ph II x4 deneb.
And the Ph II x4 940 deneb is proven to work.
So I see no reason why the Ph II x2 would not work too.
Good luck
Gyro
Discussion Starter #8
should i use this version of bios 1802? this is too old but i saw many people use this for the new cpu's
M2N Fan
I would stay with the bios you have,2001.
Good luck
Gyro
M2N Fan
i have another question about athlon x2 7850 BE. kuma core
you think i can put it ? and its am2+
It would work, but I would stick with the x2 550 or get the x4 940be.
They are much better cpu's than the Ph I 7850.
Good luck
Gyro
1 - 11 of 11 Posts
