1 - 7 of 7 Posts
My motherboard has a x16 pcie 3.0
It has a inbuilt Intel hd 530 skylake graphics card so I would like one better than this.
Also hopefully better than my older nvidia GeForce 8600 gt fatal1ty that has died.
My power supply has a 6+2 pin connector for the gpu.
Can anyone recommend a decent budget gpu. Hopefully not much more than £50.
What should be here ?
You could search online for an HD 7850 or a R9 270x or a R7 370. They fit that budget and should be great cards. What do you use your system for ? Would you go AMD if it offers better value ?
Well this is just my second computer, so it's not going to need much. It might have some games that shouldn't be too much strain, like the sims 3 or dota 2. Word documents, publisher etc.
Thanks for them I will google them, I would go amd if the price/performance was better.
Also, what exact PUS do you have ?
It seems you currently have integrated graphics that maybe barely able to do the job and since you're on the budget, I'd hold out till May end as AMD would be launching their mainstream cards that you would find a good deal in since the newer cards would be faster than the 7850 but consume less power and be cheaper.
1 - 7 of 7 Posts
