1 - 14 of 14 Posts
Hello!
I'm going to throw my Msi n460GTX hawk out. So I need a new graphic card and I've been looking at Radeon 7950 (http://dk.msi.com/product/vga/R7950-2PMD3GD5.html). And I'm quite confused if I can use it with my mobo or not.
Since it's PCI 3.0 and I'm currently using PCI 2.0.
I saw on Gigabytes site to see if it could support PCI 3.0 and I found this.
"(All PCI Express x16 slots conform to PCI Express 3.0 standard.)
* To support PCI Express 3.0, you must install an Intel 22nm CPU."
Intel 22nm CPU? ..
And I've been seeing around I need ivy bridge CPU? I'm using Intel I5 2500k sandy bridge?
I'm not a big expert when it comes to PC so sorry for stupid question
Specs
Mobo : Gigabyte z68
CPU : Intel I5 2500k @ 3,3GHz
GPU : Msi n460GTX hawk @ 900 core
Ram : 8 GB DDR3 corsair ram @ 1600MHz
PSU : Corsair 650W
Thanks for the help!
Yes, it will work perfectly fine... PCIe is backwards, forwards, upwards, and downwards compatible.
Why is your 2500k only at 3.3GHz!? Get that to at least 4GHz!
Discussion Starter #4
Thanks everyone!
Using stock cooling atm. Want Cooler Master Hyper 212 before overclocking it
PC Enthusiast
Originally Posted by G3RG View Post
They're exactly the same. They just have different fans.
And Evo is 2011 compatible
PC Enthusiast
They're exactly the same. Thus they both fit exactly the same systems.
The normal one does not come with fasteners for socket 2011, The Evo does.
They're literally the EXACT same heatsink with the EXACT same mount.
PC Enthusiast
Sigh...
Yes, But the Non Evo does not include the items you need to mount the cooler on a Socket 2011 CPU, in the Package. But the Evo does...
Hyper 212 Plus: http://www.coolermaster.com/product.php?product_id=6636
CPU Socket
Intel Socket:
LGA 1366 / 1156 / 1155 / 775 *
AMD Socket:
FM1 / AM3+ / AM3 / AM2+ / AM2
Hyper 212 EVO: http://www.coolermaster.com/product.php?product_id=6741
CPU Socket
Intel Socket:
LGA 2011 / 1366 / 1156 / 1155 / 775 *
AMD Socket:
Also:
299
There, now stop arguing if you are not sure.
Sigh...
CPU Socket
Intel Socket:
AMD Socket:
Also:
299
You are right, Non Evo have some differences from Evo... Starting from a different base and support for 2011
1 - 14 of 14 Posts
