1 - 4 of 4 Posts
Thats my PC
IntelliStation A Pro
64-bit performance, 32-bit convenience. IBM's IntelliStation A Pro is the platform of choice for your evolving world.
Series features: • Dual-capable AMD OpteronTM 200 Series processors up to 2.8 GHz; dual-core Opteron processors Model 275 at 2.2 GHz, Model 280 at 2.4 GHz
• Microsoft® Windows® XP Professional x64 Edition available preinstalled
• Red Hat® Enterprise Linux® 4 WS (64-bit) available preinstalled
• Up to 16GB1 PC3200 ECC memory (8GB per processor, dual-channel) with 128-bit controller
• PCI Express x16 2D/3D graphics from NVIDIA® with dual-display support
• Choice of SATA or dual-channel Ultra320 SCSI hard disk drives
• Scalable 6-slot x 6-bay minitower with 530W quiet power supply
And this is the case i wan
The WebSite: http://www.case-mod.com/store/aspire...13f73f80a4e444
I don't see why you couldn't, I mean all atx pcs are built on the same standard.
yeah you should be able to
the only time i havent been able to change the case on a computer is with a sony vaio
they are so customized to sony that i had to change the socket just to install a new case fan
1 - 4 of 4 Posts
