The ones made by Aerocool are pretty expensive, but I wouldn't call them good if you're going to run two fans off one channel.
Very unlikely as it only has 10watts per channel. If you're going to be putting excessive amounts of fans on a single channel you should have around 30watts per channel.Originally Posted by SirTesticlies
will this be able to handle 13 fans- 6 120 blue led uv yate loons 5 nzxt fans that come with the switch 810 (one is coming from my 410)
and 2 140 blue led uv yate loon
Y-adapters, but I'm not sure about the last fan.
Also, Lamptron makes two touchscreen fan controllers, one of them is FC Touch which features six channels, each supporting up to 30W those start at about $70. They also make CW611 geared towards watercooling, those also support 36W per channel and feature six channels they are priced around $100.
So they charge $30 more for 6watts per channel more.Originally Posted by MikhailV
The CW611 is Not a touch screen controller.Originally Posted by MikhailV
