answer: most likely. I've never played TF2 and im not sure which version of COD you are talking about, but thanks to that 4850, you should be able to max out the res and eye-candy with playable FPS.
Originally Posted by mrlinky
answer: Most likely. I've never played tf2 and im not sure which version of cod you are talking about, but thanks to that 5850, you should be able to max out the res and eye-candy with playable fps.
well i have the same 4850 and i do fine with 1680x1050 res everything maxed out, i get a good 80 FPS constantly. but i dont know about 1080 the only thing for you to do is to try it.
The 4850 does excellent in 1680x1050 but in 1080p there are clear benefits to 1gb GDDR5 (4870/90, 5xxx). Should do fine but don't expect to max out all settings.
Overclock.net
