Can I oc my E1200 more?
237 Views 5 Replies 3 Participants Last post by  WizzardOfWar
I have had my e1200 for around 2 months now and the highest i've been able to stably oc to is 3.164ghz. its not too bad, but i have heard of people getting to 3.4 or higher. The voltage i am using is 1.368 (1.35 stock) if I increased this more could i oc more? my temps have been good, idle at 91f and full load at 115f. My ram (ddr2 800) is at 800mhz with timings of 5.5.5.15. Thanks in advance, any help would be great.
1 - 6 of 6 Posts
Yeas u can. I had that chip at 3.5 for some time, before I got my E74.
Those chips are tough as hell. If you want to push it higher, just give it more volts. I am not sure what your temps are (everybody uses C not F) but as long as you are under 65-70C you have nothing to worry about.
is my psu strong enough?
As long as it of decent quality, it is more than enough.
ok! now im at 3.365! and stable!
1 - 6 of 6 Posts
