1 - 3 of 3 Posts
Do you think I can overclock my PC?
Pentium 4 2.4Ghz HT
1GB DDR Kingston ram
ATi 9800XT
Intel 865GBF
Welcome to the forums.
I moved your post to a new thread as your question is a separate issue from the thread you posted in.
Unfortunately, since you have an Intel motherboard, it's unlikely that you can overclock through the BIOS, which is the best means of overclocking. It's possible that you can overclock through software; just make sure you find a program that's compatible with your exact board.
1 - 3 of 3 Posts
