Can I place side panels fans on HAF if I have CM V8?
424 Views 7 Replies 3 Participants Last post by  allenkane
Topic.
Thanks In Advance.
EDIT: HAF922
1 - 8 of 8 Posts
According to this thread: http://forum.coolermaster.com/viewto...st=0&sk=t&sd=a
It shouldn't be a problem
Good luck
LOL you found my post asking a similar question. That reminds me, they never answered my question about the 200mm fan.
If you're looking for the exact same fan, http://www.newegg.com/Product/Produc...-072-_-Product
The one you posted originally, http://www.newegg.com/Product/Produc...-067-_-Product, is technically designed for the CM Storm Sniper but will fit the HAF 922 as well. It does push more air but will run at a higher RPM (louder) if @ max speed (or quiter @ lowest speed).
Edit: The second fan won't be able to utilize the red LEDs when put inside of the HAF 922.
Thank you, i should have just posted here in the first place.
EDIT: LOL
Newegg? out of stock
Tigerdirect? out of stock
Amazon? out of stock
wat?
EDIT: LOL
wat?
There's a few stores that claim to have them in stock; not my choice of stores but what else do you wanna do
http://www.google.com/products/catal...409&sa=title#p
thanks a lot, appreciate the reply.
so this is the exact same fan stock on the haf 922 thats in front for confirmation?
Yeah, that's it
1 - 8 of 8 Posts
