Originally Posted by jethro_static
That's not what I meant. If he can afford a 3dtv, He can afford a better card for other use like extreme gaming.
Since he is using a Sempron CPU, this is most likely a dedicated HTPC.
Just because you have money does not mean you should spend it.
Just because you have fit more powerful components does not mean it is worth it due to heat, power, and noise.
Like I said, You need the 3d glasses to use the card. Someone said he does not need 3d glasses if you have 3dtv. Why do you need the card if you have 3dtv?
HDMI 1.4a
