Ok, so i've got the 7850 BE and i am running at 3,2GHZ (207 x 15.5)..
Here's my temps with Everest:
Idle :
CPU Temp : 50'c
Core 1 : 30'c
Core 2 : 30'c
Under load (Prime95):
CPU Temp : 67'c
Core 1 : 50'c
Core 2 : 50'c
I want to try and push this card to 3.3 maybe 3.4 but with only stock HSF and 2 case fans (stock - guessing low RPM?) I'm worried about temperatures.. Do i measure from the core temps or the CPU temp?
It says here : http://products.amd.com/pages/Deskto...il.aspx?id=535
That my CPU handles up to 73'c but my friend says that's the heat when the CPU dies. Does raising clock speeds without raising the voltage cause a change in temps?
Thanks in advance!
Idle :
CPU Temp : 50'c
Core 1 : 30'c
Core 2 : 30'c
CPU Temp : 67'c
Core 1 : 50'c
Core 2 : 50'c
Thanks in advance!
