1 - 20 of 20 Posts
· Watercooler
So I just bought my third Kingston HyperX SATA3 120GB. I have the first two in Raid 0 and I would like to re-install windows and set up all 3 SSD's in Raid 0. I do know that if one fails they all fail but I want to try this anyways. I have an asrock z77 extreme4 mobo and an intel 3570k so if you guys can help that would be great!!!
· Watercooler
Ok awesome thanks! So excited!!
· Watercooler
Oh my god I hate my life right now I totally thought I had 4 sata3 ports for some reason. Aghh what am I going to do with this drive now? How do I make it so that I can install programs onto this drive since it does not have c/programs on it?
· Watercooler
Discussion Starter · #6 ·
How much of a performance decrease will I get with 3 in raid 0? With one on an sata2 port? Because I bought it already and opened the box:-(
· Watercooler
Ok so now I'm confused because I just got home and I'm looking at my motherboard and sata3_a1 sata3_a0 sata3_1 and sata3_0 are all sata3 ports. So I can put three in raid 0? Right? I have 8 sata ports. Four are sata2 and four are sata3.
· Premium Member
Do all three go to your raid controller? If so, then you can.
(edit) according to newegg, your controller only supports two SATA 6:
4 x SATA2 3.0 Gb/s and 2 x SATA3 6.0 Gb/s by Intel Z77, support RAID 0, RAID 1, RAID 5, RAID 10
· Premium Member
You may have 4x SATA3 but only 2 of those are Intel. I'm guessing the other 2 are Marvell. If you plan on using the built-in RAID on your motherboard, you won't be able to mix and match. You'd have to use all Intel ports for RAID.
As for performance, you could probably get around 900-1000MB/s sequential with compressible data on 2-way RAID-0 SATA3. If you go 3-way RAID-0 SATA2, you'll probably be looking at around 750MB/s sequential max.
· Watercooler
Discussion Starter · #11 ·
So I am installing windows on a 3-way SATA.... 2 Raid 0 right now. I just want to see if I would even notice any difference. Total bummer I got myself all excited again
· Watercooler
Discussion Starter · #12 ·
So its not too bad I don't really notice too much of a difference. How do Raid cards work? Would I be able to buy one that would work with 3 SSD's in Raid 0 using SATA 3?
· Premium Member
Yes something like this would do that: http://www.newegg.com/Product/Product.aspx?Item=N82E16816115114
You plug it into the pci-e slot, and plug the drives into it instead of your motherboard. The BIOS will see the drives just like the controller was onboard. The advantage to this method is that you can migrate the array to a new motherboard and keep all your data, since you would be using the same controller.
· Watercooler
Discussion Starter · #14 ·
Ok guys so I noticed that things were slower with my 3-way sata2 Raid 0 set-up so I am currently setting up windows and am just going to use the 3 SSD's as 3 seperate storage disks. So I definetly plugged my new drive into one of the two remaining SATA3 ports and it shows in my BIOS, but when I went to install windows I could only see 2 of my 3 SSD's when deciding where to install windows. I am waiting for it to complete right now, but why is it doing this? If I can't use this 3rd drive as an SATA3 I am going to be VERY dissapointed.
· Ever Forward.
As per the usual, it'd be slightly slower with just the 2 ssds on sata 6 in raid 0 as well.
That third drive is probably in a locked state.
· Watercooler
Discussion Starter · #16 ·
BTW I have an Asrock Z77 Extreme4 MOBO. I know I said that before, but some people don't like reading through the whole thread. Thanks guys! I did try to search for an answer, but I couldnt find one. I'm new at all of this stuff, but I'll update if I can figure this out.
· Watercooler
Discussion Starter · #17 ·
What do you mean locked state? How do I unlock it?
· Watercooler
Discussion Starter · #18 ·
I figured it out. I scrolled over computer and right clicked and then clicked manage and in that window went to disk management and formatted the drive, but when I am in BIOS it doesnt give me options in the new ssd like it does with the older ssd. Options like hot pluggable and SATA type. Why does is that?
· Ever Forward.
Full shutdown and power on should do it but formatting works too I guess; the drive probably was in a raw state as well after breaking the raid array.
No idea about the bios.
· Premium Member
The only way you are going to get the full benefit from the 3 drives in RAID0 is with a hardware RAID card, and not the cheap ones but rather from the likes of Areca, LSI, 3ware, etc.
If you have, or intend to have, a lot of storage devices then this is not a bad idea, but if it's just for the 3-SSD RAID0, then spending$500+ for a kickass card will be kind of pointless...
1 - 20 of 20 Posts
