1 - 8 of 8 Posts
Hey guys and girls! I just ordered a new pc and I supposed to get it sometimes next week. I'm sure you guys get this question a lot of the time, but if you look in my build, does anyone with about the same specs tell me If it can play BF3 and other new games on Max settings? If not wich settings? Thanks! And also, sorry if this is the wrong place, but I could not find any section that was really appropriate for this topic.
Yes
It will run on max with HBAO off and low AA @ low 40's to high 50's fps.
Some map require more juice, some other less. You will run BF3 almost maxed out.
that'll work, my sig rig can run it at about 40-50 fps, and when things get busy 30-40 fps, almost never drops below 30, and on ultra, so you'll be good!
1 - 8 of 8 Posts
